[Qgis-user] Labeling Lines with Bearings
Springfield Harrison stellargps at gmail.com
Thu Feb 3 00:37:02 PST 2022
Hello Phil & Calvin,
Thanks very much to you both for those tips.
The Vector Shake Tools options were good but required some extra work to
transfer the new information to the existing layer.  I think I could
have made it work but then found one of the options in Stack Exchange to
be exactly what was needed.
This is it:
"And now it is even easier than Kay's answer -first use 'explode lines'
tool, yielding all line segments, then calculate azimuth with field
calculator: *main_angle($geometry)*".
This is brilliant, it can be used to populate an attribute field in the
table or directly in a label formula as desired.  Exactly the solution I
was looking for!
Thanks very much to you both, this is a great resource…
Cheers, Spring
On 02/Feb/2022 16:58, Phil Wyatt wrote:
> Hi Spring,
> Bottom  couple of posts in this stackexchange question should get you started
> https://gis.stackexchange.com/questions/55449/how-do-i-find-vector-line-bearing-in-qgis-or-grass
> Cheers - Phil
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Springfield Harrison
> Sent: Thursday, 3 February 2022 10:30 AM
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Labeling Lines with Bearings
> Hello,
> I need to put the line direction (azimuth) into a line label. Some searching has not come up with anything.
> Is there a way?  Thanks very much . . . .
> Cheers, Spring
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220203/30fdc3f7/attachment.html>
