[Qgis-user] Include Comment in source Query
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Feb 3 10:54:57 PST 2022
mhm, seems to be this open issue maybe
https://github.com/qgis/QGIS/issues/38359
Am 03.02.22 um 19:34 schrieb Hugh Kelley:
> Ah thanks yes agreed on the shp front.
> I'm not finding success with gpkg using QGIS 3.16.11 either though.
> On Thu, Feb 3, 2022 at 1:27 PM Bernd Vogelgesang
> <bernd.vogelgesang at gmx.de> wrote:
>     Hi,
>     here are my findings from 2015:
>     https://gis.stackexchange.com/questions/107522/is-it-possible-to-use-comments-in-qgis-query-builder-with-esri-shapefiles/149448#149448
>     In short: comments with shape files did not (do not maybe still ) work
>     Solution: Just do not use ESRI-Shape files for work ;)
>     Cheers,
>     Bernd
>     Am 03.02.22 um 15:33 schrieb Hugh Kelley:
>>     Very helpful point, it is a shapefile.
>>     so far "#", "--", "//" and "/* */" did not work. I also tried
>>     "<!-- comment -->" for good measure which didn't work as well.
>>     I tried a few of those on a geopackage too  and they errored out
>>     there as well.
>>     I'll try a postgis datas source later today if I remember.
>>     On Thu, Feb 3, 2022 at 9:23 AM Johannes Kröger (WhereGroup)
>>     <johannes.kroeger at wheregroup.com> wrote:
>>         Hi Hugh,
>>         that depends on the provider in use, a PostGIS provider might
>>         behave differently from a Shapefile. See if wrapping the
>>         comment in /* comment */ works.
>>         Cheers, Hannes
>>         Am 03.02.22 um 15:16 schrieb Hugh Kelley:
>>>         Hi all,
>>>         in the Layer Properties >> source >> Query Builder dialogue,
>>>         if I use "--" it shows that I've commented out that line.
>>>         when I test the query though, it throws an error complaining
>>>         about the comment I included.
>>>         Is there a way to include a comment in the query?
>>>         i've like to include a note to myself when I filter things
>>>         sometimes as it can be hard months or years later to figure
>>>         out the motivation. for example:
>>>         -- remove built neighborhood bikeway according to KML file
>>>         from client, per email 2022-02-03
>>>         "LOCAL_ID" NOT IN (4030, 3533, 4307, 6015, 5217)
>>>         Maybe there's a better way to include this note, but it
>>>         seems that the closer the note is to the filter query
>>>         definition the more likely I am to see it.
>>>         thanks
>>>         Hugh
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         Qgis-user at lists.osgeo.org
>>>         List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Johannes Kröger / GIS-Entwickler/-Berater
>>         WhereGroup GmbH
>>         Grevenweg 89
>>         20537 Hamburg
>>         Germany
>>         Tel: +49 (0)228 / 90 90 38 - 36
>>         Fax: +49 (0)228 / 90 90 38 - 11
>>         www.wheregroup.com  <http://www.wheregroup.com>
>>         Geschäftsführer:
>>         Olaf Knopp, Peter Stamm
>>         Amtsgericht Bonn, HRB 9885
>>         Schon gewusst?
>>         In unserem Blog geben wir Tipps & Tricks zu
 Open-Source-GIS-Software
>>         und berichten aus unserem Experten-Alltag:
>>         https://wheregroup.com/blog/
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Hugh Kelley
> Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220203/a195860a/attachment.html>
