[Qgis-user] FW: RE: Labeling Lines with Bearings
Springfield Harrison stellargps at gmail.com
Fri Feb 4 02:34:29 PST 2022
Aha, thanks Kirk.  That's why my lines are not as I intended. This
probably affects making the lines with the Shape Tool.
Yes, it seems to draw in grid north, angle_main reports in True DD.  The
map is 26907, UTM 7N.
I calculated the difference between as drawn and as reported and used
that to change the input figure.  It works OK, not exact as the
convergence varies with longitude, I believe.
Thanks Kirk . . . .
Cheers, Spring
On 03/Feb/2022 02:59, kirk wrote:
> Sent from my Galaxy
> -------- Original message --------
> From: kirk <kirk at nortekresources.com>
> Date: 2022-02-03 5:55 a.m. (GMT-04:00)
> To: Springfield Harrison <stellargps at gmail.com>,
> qgis-user at lists.osgeo.org
> Subject: RE: [Qgis-user] Labeling Lines with Bearings
> Hi Spingfield.
> I use a little routine and the core if it is:
> main_angle($geometry) which you can use in field calculator.
> Note this will give you the azimuth in relation to grid north for the
> coordinate system you are using.  For projections, you will need to
> lookup or calculate convergence to get the adjustment to true north.
> Kirk Schmidt
> Sent from my Galaxy
> From: Springfield Harrison <stellargps at gmail.com>
> Date: 2022-02-02 7:30 p.m. (GMT-04:00)
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Labeling Lines with Bearings
> Hello,
> I need to put the line direction (azimuth) into a line label. Some
> searching has not come up with anything.
> Is there a way?  Thanks very much . . . .
> Cheers, Spring
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220204/450e0b4f/attachment.html>
