[Qgis-user] Opacity issue when importing shapefiles
Matej Molčan
matej.molcan at protonmail.com
Mon Feb 7 07:18:32 PST 2022
Thank you for the solution. It worked.
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrea Giudiceandrea
Sent: 07 February 2022 11:40
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Opacity issue when importing shapefiles
> Matej Molčan[matej.molcan at protonmail.com](mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Opacity%20issue%20when%20importing%20shapefiles&In-Reply-To=%3C00d501d81c0c%240c6b3f10%242541bd30%24%40protonmail.com%3E)
> Mon Feb 7 02:18:29 PST 2022
> I have an issue with a QGIS project regarding opacity settings. Every time I import a shapefile into the project, the opacity is set at 0 % and has to be manually increased to 100 % in order to see the feature. I have never had this issue, except only in this particular QGIS project.
Hi Mat,
probably a default style was set for that project.
You can change if from Project properties -> Default Styles.
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220207/c731b3e1/attachment.html>
