[Qgis-user] Center line of an elongated BASIN
Zoltan zoltans at geograph.co.za
Thu Feb 10 23:21:04 PST 2022
I'm coming in late to this methodology discussion, so apologies if I am
off the mark.
So by 'center line' I'm guessing you mean a line that is always
equidistant from the polygon boundary.
I had a similar problem a few years back where I had to create road
center lines from a polygon road representation for a small country.
After some experimentation on speed and efficacy, I came up with a
Python script that:
    merged (dissolved) all poygons) - but you only have 1 polygon :-)
    rasterised the polygon (as finely as you choose relevant to your issue)
    ran r.thin
    vectorised the (now) single line of cells.
    ran a Douglas-Peuker style smoothing on the staircase lines
Worked like a dream for my purpose.
Maybe you could adapt this logic flow to your needs?
HTH,
Zoltan
On 2022-02-11 00:46, Allan López wrote:
> Yes, it does.
> Thanks a lot indeed. I am testing it.
> Best,
> Allan
> El jue, 10 feb 2022 a la(s) 15:19, Alexis R.L. (alroyliz0 at gmail.com)
> escribió:
>     As far as I know v.voronoi.skeleton in gdal is the closest thing
>     we have that can do this in base QGIS.
>     I hope this helps,
>     Alex
>     Le mer. 9 févr. 2022 à 17:57, Allan López <allosa01 at gmail.com> a
>     écrit :
>         Dear All, I need to calculate and display the center line of
>         an elongated river basin ( not the center of the main river
>         trunk) from a SHP.
>         Thank's in advance.
>         Allan Lopez
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220211/db7aebf1/attachment.html>
