[Qgis-user] linux box accessing project-files on a windows server
Patrick Dunford enzedrailmaps at gmail.com
Mon Feb 21 17:42:45 PST 2022
the /run path in Linux shouldn't be used for file access as it is
intended for use by applications, not by end users.
If you have a file share to access in Linux, mount it to a path in your
home folder or perhaps off from /mnt and assign the permissions required
to access it there.
On 22/02/22 04:49, Richard Greenwood wrote:
> I did a quick test. I installed QGIS 3.22 on a Windows 7 computer,
> created a project. Switched to Linux Mint, used the file manager to
> navigate to the Windows computer, double clicked the project and it
> opened correctly. The path that QGIS displays in the properties/info
> panel is:
> Path
> /run/user/1000/gvfs/smb-share:server=w7,share=c$/Temp/ASSESSOR_ROADS_2018_3.shp
> I went back to the Windows computer, exported the shapefile to a gpkg,
> saved the project. Reopened it in Mint, all good. QGIS info for the
> gpkg layer:
> Path
> /run/user/1000/gvfs/smb-share:server=w7,share=c$/Temp/test.gpkg
> I also tested putting the gpkg in a folder below the project file and
> that opened correctly on the Linux computer.
> So I suggest that you start with a simple test project. Also, the
> project .qgz file is just a gzipped xml file. So you can unzip it,
> open the .qgs file in a text editor and search for "source=" to see
> what path info has been saved with the project.
> Rich
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220222/cae29709/attachment.html>
