[Qgis-user] QGIS on MacOs question
Agustin Diez-Castillo gvsig.mac at gmail.com
Sat Feb 26 11:10:45 PST 2022
The case is the same in Mac, push the three dots on the right and go to your project folder.
If this is not the case, check the project folder permissions (command I) and try again.
A.
> On 26 Feb 2022, at 09:39, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 2/26/22 01:16, Richard Welty wrote:
>> after a bit of a layoff and a MacOS upgrade or two, i'm back to
>> using QGIS for a project. just upgraded to the current LTR,
>> running on Big Sur.
>> can anyone shed light on how to deal with the MacOS permission
>> system? I can load up the shapefiles fine, pick out the features
>> i need, but when i go to export that layer, it's complaining about
>> a read only file system. i'm not at all clear on where to find
>> & fix the settings.
> Richard, could it be that you only provide a name for the export? In the dialog it is intuitive to only type a name, but actually you need to browse to a directory first (using the little dots next to the input) and THEN add a name.
> Without the path QGIS tries to save it in 'current dir' which is probably the directory in which QGIS is installed...
> Note this is my experience with other users on Windooz, I'm not a mac owner/user
> Regards,
> Qgis-user mailing list
