[Qgis-user] QGIS Modeling, using an model input layer name
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Jan 7 11:42:42 PST 2022
I'am not trying to use the field calculator on the raster.  I am trying
to use the layer name of the raster as value.  This value then goes into
the field calculator.  This is in a QGIS model.
Hope this is clearer.
Thanks
Nicolas
On 2022-01-07 2:07 p.m., Kirk Schmidt wrote:
> Hi Nicolas
> The field calculator will not process raster data.  Try using the
> raster calculator
> Kirk Schmidt
> On 1/7/2022 2:56 PM, Nicolas Cadieux wrote:
>> Hi,
>> I can figure this on out!!!  I want to use the layer name of the
>> input layer (a raster) as value for the field calculator.
>> layer_property(@Inputraster , 'name')  does not work.  Any suggestions?
>> Thanks
Nicolas Cadieux
https://gitlab.com/njacadieux
