[Qgis-user] Readonly gpkg
Greg Troxel gdt at lexort.com
Tue Jan 11 17:40:21 PST 2022
Nyall Dawson <nyall.dawson at gmail.com> writes:
> On Wed, 12 Jan 2022 at 11:00, Greg Troxel <gdt at lexort.com> wrote:
>> <pergler at gmail.com> writes:
>> > A. Ideally WAL/DELETE would be a connection (in the sense of the
>> > Browser connections list) level decision changeable by the user, not a
>> > layer-level decision and not (as now) an application setting used for
>> > all gpkg connections.
>> Fundamentally WAL/DELETE is a (changeable) property of an sqlite3 file,
>> and thus of a geopackage container.  So exposing it as a db browser
>> property and allowing it to be changed, with a warning that it is a DB
>> Admin operation, not a connection operation, seems ok.
> Instead of exposing this as a per-workstation, QGIS only property, I'd
> propose instead that the property be set somewhere in the gpkg
> metadata itself, so that regardless of which user opens it in a
> multi-user environment, they'll always get the property set by the db
> administrator. (Maybe this could even become a future formal gpkg
> extension...?)
Right now, I think WAL/DELETE is a property of the sqlite3 file which
contains the geopackage data.  But it's a sqlite3 property, not a
geopackage property.  (And qgis whacks it on every open.)
If I am following, you are suggesting a geopackage-level property (in
some table?), and a rule that when a reader or write opens the file, if
the sqlite3 setting does not match, the sqlite3 setting is forced and an
error is logged?   If I got that wrong which I probably did, I wonder
what you do mean.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220111/db4adf15/attachment.sig>
