[Qgis-user] loading geologic symbol library
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Jan 13 04:32:29 PST 2022
Hi Benoit,
I just tried to import the symbols from the page you mentioned which
leads to this repository: https://github.com/BC-Consulting/FGDC-4-QGIS/
Now, even with all explanations given, the import seems not to work
properly.
no matter what path I add for the FDGC folder (just the .../FDGC or the
.../FDGC/svg path) , on import, it says, that
- the symbols are already there and gives the option to overwrite or skip,
- the option to add comma-separted tags (e.g. Geology) does not work,
and no tag at all is given
- all symbols are just question marks
Are those guidelines just precisely unprecise, or am I just to dumb to
understand whats asked from me?
Cheers
Bernd
Am 13.01.22 um 07:56 schrieb info:
> Hi Byron,
> *Settings -> Style Manager... -> Import/Export -> Import Item(s)...*
> See https://www.geoproc.com/be/qgis-fgdc.htm for more info.
> Best regards,
> Benoit
> On 12/01/2022 23:12, Firstname Lastname wrote:
>> i have download a geologic symbol library from Rod Holcolme, a
>> geology prof in australia.  i have set up the path for the files via
>> the Options>system>.svg path.
>> this seems to have linked to the directory, but i can not figure out
>> how to see the files.
>> within the directory, there are several files that show up as
>> microsoft edge html files with the file types as shown below.
>> GeoQSymbols/DipDir/001%20Bedding%20(dipdir).svg
>> Can anyone help me to get these imported.  i can not get them imported .
>> thanks for your help
>> Byron Veilleux, MSc. P.Geo
>> Conjugate Geologic Services Limited
>> Calgary, Alberta Canada
>> byron at conjugategeo.com
>> Cell:4037108414
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220113/d7957a72/attachment.html>
