[Qgis-user] Deleting a vertices during tracing in of a polygon - Is there a way?
Harrissou s. delazj at gmail.com
Fri Jan 14 22:31:07 PST 2022
Press DEL or Backspace key. Info at https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#digitizing-an-existing-layer
Regards,
Harrissou
Le 15 janvier 2022 02:09:06 GMT+01:00, Jeff Sonnentag <jsonnentag at llenviroinc.com> a écrit :
>Searching I can't find anything on the topic (or I don't know what to search for . . .), but when you are tracing around something and creating a new polygon (or line) and you click and place a vertex in the wrong spot is there an way to IMMEDIATELY do some kind of UNDO to remove either the last vertex placed or the last few or something.
>"Undo" under "Edit" isn't available and Ctrl-Z doesn't do anything.  (???)
>I just got done tracing in a large item after a few hours and I think I got all the places I messed up found (by following the edge around and looking at everything again AFTER saving the whole traced feature), but it would be a LOT more efficient to be able to deleted some last created vertices as the shape was being created and as mistakes were known to have been made.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220115/a8d27cc5/attachment.html>
