[Qgis-user] Issue with libQt5Core when running QGI 3.22 via singularity
Shan-ho Tsai shtsai at uga.edu
Tue Jan 18 10:18:31 PST 2022
Hello,
I'm trying to run QGIS 3.22 on an HPC cluster. Docker is not available on the cluster, but Singularity is. I created a singularity image from the official docker container documented at https://hub.docker.com/r/qgis/qgis. The command I used to create the singularity image is
singularity pull docker://qgis/qgis
and this created qgis_latest.sif
But when I run it via Singularity, I get the error that libQt5Core.so cannot be found:
[shtsai at b1-24 ~]$ singularity run qgis_latest.sif qgis --help
/usr/bin/qgis: error while loading shared libraries: libQt5Core.so.5: cannot open shared object file: No such file or directory
This library is available in the container, but perhaps the library path is not set up correctly for using it via Singularity:
[shtsai at b1-24 ~]$ singularity run qgis_latest.sif ls -l /usr/lib/x86_64-linux-gnu/libQt5Core.so
lrwxrwxrwx 1 root root 20 Jan  5 13:54 /usr/lib/x86_64-linux-gnu/libQt5Core.so -> libQt5Core.so.5.12.8
[shtsai at b1-24 ~]$ singularity run qgis_latest.sif ls -l /usr/lib/x86_64-linux-gnu/libQt5Core.so.5.12.8
-rw-r--r-- 1 root root 5519624 Jan  5 13:54 /usr/lib/x86_64-linux-gnu/libQt5Core.so.5.12.8
Any thoughts why this error occurred and how I can resolve it?
Thank you in advance.
Regards,
Shan-Ho
Shan-Ho Tsai
GACRC/EITS, University of Georgia
Athens, GA 30602
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220118/831c2b1f/attachment-0001.html>
