[Qgis-user] Update Null Geometry
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jan 20 08:14:22 PST 2022
Hi Hugh,
Are you working with a CSV file? Or is it a shapefile?? Im not sure if this will work, but create a new point for a null geomety, you can then, using the Attribute table (in edit mode), Merge Features, by selecting the new geometry and the table row without geometry, then selecting Merge Features[cid:image001.png at 01D80E18.C81AC070] The popup will then allow you to merge the two, you can select the row without geometry and select “Take attributes from selected feature” this should merge your new geometry with the attribute.
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Hugh Kelley
Sent: 20 January 2022 16:01
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Update Null Geometry
Hi all,
I have a points dataset with a few null geometries in it.
Is there a tool that can update these in place?
It seems that the point editing tool must add a new row instead of updating an existing row.
The vertex editing tool seems unable to update a null geom since there's nothing to initially click on.
Maybe I'm missing a tool or way of using the vertex editing tool?
A less preferred workflow would be to create a separate file and manually add the points with the primary key as an attribute to later update on in postgres but it would be much cleaner to edit the table in place I think and I am curious if there is a solution since I'm not thinking anything up myself.
Thanks for any suggestions.
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/e805e294/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/e805e294/attachment-0001.png>
