[Qgis-user] Array --> Generate_Series
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Fri Jan 21 03:33:33 PST 2022
Hey Miquel,
make sure the data type of the field you want to insert the result to
matches the data type of the result itself. You might need to convert an
array to a string if I understand you correctly.
Cheers, Hannes
Am 21.01.22 um 12:04 schrieb Miquel Pujol Garcia:
> *Hello Qgisers,*
> I'm trying to insert in a field* a serial data number (2,4,6,8,10,...)
> using _generate_series_ from array group. When I purpose the
> syntax in Calculate Camps in the table, I can see the correct
> result but when I execute the values aren't inserted in the field.
> The objects are lines in a Geopackage.
> Does someone use generate_series and know-how run well?
> *field = enter number: long 10
> Thanks,
> *Miquel*
> Qgis-user mailing list
Johannes Kröger / GIS-Entwickler/-Berater
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu
Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/8c328ddc/attachment-0001.html>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/8c328ddc/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/8c328ddc/attachment-0001.sig>
