[Qgis-user] model builder - merge several inputs
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Jan 26 08:20:32 PST 2022
You could try a "join attribute by location" followed by a "Aggregate"...
Nicolas
On 2022-01-26 3:43 a.m., Simon Dietmann wrote:
> Dear list,
> I am trying to find a solution for the following problem with the
> model builder:
> My model asks for two vector polygon layers that will be combined by
> ‘union’. The resulting layer gets a new field (field calculator) and
> is evaluated by ‘Statistics by categories’ algorithm. The fields for
> the categories are selected by the user when calling the model. Since
> those fields are present in the two separate input layers, I have to
> use two separate ‘Vector field’ inputs.
> The problem arises when I try to combine those two input variables to
> use them together for the ‘Statistics by categories’ algorithm. AFAICS
> there is no function inside the model builder to achieve this, so I
> suggest I have to export the model as a python script. There I found
> that the call of the Statistics function gives the name of the
> variable as a parameter and not the variable itself:
> alg_params = {
> 'CATEGORIES_FIELD_NAME': parameters['fields'], ….
> How can I combine my two lists (~like “parameters[‘fields’+’fields2’],
> or is there a way to do this inside the model builder that I didn´t find?
> Thanks in advance for help, kind regards
> Simon Dietmann
> Mit freundlichen Grüßen
> im Auftrag
> Simon Dietmann
> M.Sc. Physische Geografie
> Aufgrund der aktuellen Situation bin ich zur Zeit vermehrt im Home
> Office tätig und dort erreichbar unter +49 69 – 57 80 56 98 oder per
> Email, ich rufe Sie dann gerne zurück.
> PGNU Planungsgesellschaft Natur & Umwelt mbH
> Amtsgericht Frankfurt am Main, HRB 111938
> Geschäftsführer: Dr. Benjamin Hill, Johannes Christoph Kress,
> Alexander von Küchler
> Hamburger Allee 45 +++ D-60486 Frankfurt am Main
> Durchwahl: +49 (69) 95 29 64 - 75 +++ Fax: +49 (69) 95 29 64 – 99
> E-Mail: dietmann at pgnu.de <mailto:dietmann at pgnu.de> +++ Web:
> www.pgnu.de <http://www.pgnu.de/>
> > Diese E-Mail könnte vertrauliche und/oder rechtlich geschützte
> Informationen enthalten. Wenn Sie nicht der richtige Adressat sind
> oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte
> sofort den Absender und vernichten Sie diese Mail. Das unerlaubte
> Kopieren sowie die unbefugte Weitergabe dieser Mail sind nicht gestattet.
> > This e-mail may contain confidential and/or privileged information. If you are not the intended recipient
> (or have received this e-mail in error) please notify the sender
> immediately and destroy this e-mail. Any unauthorized copying,
> disclosure or distribution of the material in this e-mail is strictly
> forbidden.
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220126/8d7ee640/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220126/8d7ee640/attachment-0001.jpg>
