[Qgis-user] topological editing geographic data fails
Klaus Mithöfer mithoefer at gbd-consult.de
Thu Jan 27 03:19:34 PST 2022
Hello List,
I tried to edit geographic data (Linestrings, 4326) in a Geopackage but
I failed to use the topological editing to move joint vertices. I also
had problems with snapping on segments and/or vertices. It always
snapped to the next vertex (snapping distance in pixel).
Does it work with projected data only?
If I reproject the layer to UTM 25832 everything is fine.
I work with QGIS 3.16
Kind regards, Klaus
