[Qgis-user] Shapefile to KML conversion
krishna Ayyala ayyalakrishna at gmail.com
Mon Jul 11 07:03:47 PDT 2022
Thank you. Geopackage worked.
Regards.
On Sun, Jul 10, 2022 at 1:12 PM Raul Ayala Domingo <raulayaladom at gmail.com>
wrote:
> 5 GB is too large for a shapefile.  I think 2GB is the limit for a
> shapefile, so it is possible you are loading an already failed, corrupted
> or incompleted shapefile. Then export results in a empty file.
> You should use geopackage to manage this large info, or some spatial
> database as PostgreSQL-PostGIS, spatialite… and then export it to KML.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220711/b98df87c/attachment.htm>
