[Qgis-user] OSGeo4W Shell with Unix-Style Terminal?
Mike Treglia mtreglia at gmail.com
Tue Jul 12 06:14:23 PDT 2022
Thanks, Jurgen! Much appreciated!
I haven't had luck yet, but if I get it to work, will let you all know what
the solution is.  From what I've found, it seems like git bash is based on
msys2, and changing "cmd /c" to "cmd //c" lets something run for fetchenv,
but gdal commands are not available after I run it.
Again, much appreciated, and more later if I figure it out!
Mike
On Thu, Jul 7, 2022 at 6:00 PM Jürgen E. Fischer via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi Mike,
> On Thu, 07. Jul 2022 at 17:31:26 -0400, Mike Treglia wrote:
> > So I've added the below to my profile (from the link you've previously
> > shared), and I can run 'fetchenv /c/OSGeo4W/bin/o4w_env.bat' from my bash
> > terminal - and it starts the process, but it either is getting hung up,
> or
> > is just taking longer than I anticipated - is it something that does take
> > some time and I just need to let it run, so be patient? Or am I maybe
> > missing or need to adjust something else?
> Not sure - I use cygwin's bash and with that it works.  Other shells might
> behave differently.
> msys for instance has problems with plain /c in the cmd call and needs //c
> (see
> https://github.com/OSGeo/grass/blob/main/mswindows/osgeo4w/package.sh#L33)
> Try set -x to get some more insight what it does and where it hangs.  It
> might
> take a few seconds, but no minute.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220712/98da36cb/attachment.htm>
