[Qgis-user] GRASS r.series - ERROR: Unable to load GDAL library
Andrea Giudiceandrea andreaerdna at libero.it
Mon Jul 18 08:01:12 PDT 2022
Il 18/07/2022 13:20, Nelson Ribeiro ha scritto:
> Thank you very much for your support, I have
> installed QGIS 3.22.8 - OSGeo4W-3.22.8-4.msi Standalone Installer
Hi Nelson,
please read my second reply message:
Il 17/07/2022 11:59, Andrea Giudiceandrea ha scritto:
> Hi Nelson,
> I can replicate the same issue using v.sample instead of r.series.
> You can workaround the issue just copying the file "gdal305.dll", that
> is present in your QGIS installation directory under the \bin\ folder,
> with the name "gdal304.dll" in the same folder.
> See https://github.com/jef-n/OSGeo4W/pull/10.
In addition to the above workaround, know that the issue has been
already fixed and it will hopefully not occur in the upcoming QGIS
3.22.9 Standalone Installer.
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220718/521af9da/attachment.htm>
