[Qgis-user] GRASS r.series - ERROR: Unable to load GDAL library
Nelson Ribeiro nelsonrrf at hotmail.com
Wed Jul 20 00:31:00 PDT 2022
Dear Andrea,
Confirmed!
Thank you.
Regards,
Nelson
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: 18 July 2022 16:01
To: Nelson Ribeiro <nelsonrrf at hotmail.com>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GRASS r.series - ERROR: Unable to load GDAL library
Il 18/07/2022 13:20, Nelson Ribeiro ha scritto:
Thank you very much for your support, I have
installed QGIS 3.22.8 - OSGeo4W-3.22.8-4.msi Standalone Installer
Hi Nelson,
please read my second reply message:
Il 17/07/2022 11:59, Andrea Giudiceandrea ha scritto:
Hi Nelson,
I can replicate the same issue using v.sample instead of r.series.
You can workaround the issue just copying the file "gdal305.dll", that is present in your QGIS installation directory under the \bin\ folder, with the name "gdal304.dll" in the same folder.
See https://github.com/jef-n/OSGeo4W/pull/10.
In addition to the above workaround, know that the issue has been already fixed and it will hopefully not occur in the upcoming QGIS 3.22.9 Standalone Installer.
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220720/8a1f1362/attachment.htm>
