[Qgis-user] Export gpx?
Ramon Andinach custard at westnet.com.au
Sun Jul 24 13:17:50 PDT 2022
Hi David,
The GPX format is only able to have points and lines. You’ll need to convert the polygon into a line first, and there is something in the vector menu that will do this.
(Points map to waypoints, lines map to tracks.)
Regards,
Ramon.
> On 25 Jul 2022, at 03:52, David Witton via Qgis-user <qgis-user at lists.osgeo.org> wrote:
> I'm trying to transfer the boundary of a property that is displayed in a vector layer in QGIS 3.16.15  into a mapping software. My first thought is to select the row in the attribute table, then export it as a .gpx file.
> However I'm getting an error "Geometry type of 'Multi Polygon' not supported in GPX.
> Is what I'm trying to do possible using another format?
> David Witton
> 307 413 2072
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220725/3d5d49a4/attachment.htm>
