[Qgis-user] DB manager PostGIS import fails for strange reason
Mats Elfström mats.elfstrom at giskraft.se
Tue Jul 26 02:31:29 PDT 2022
Hi!
This regards QGIS version 3.26.0-Buenos Aires.
Attempting to import a gpkg poly layer to PostGIS I get this unexpected
error.
*Error 6*
*Feature write errors:*
*Creation error for features from #-9223372036854775808 to
#-9223372036854775808. Provider errors was: *
*PostGIS error while adding features: ERROR: Geometry type (MultiPolygon)
does not match column type (Polygon)*
*Only 0 of 179 features written.*
There is no option to set geometry type in the import settings, and a
MultiPolygon table should anyway be able to accept single polygons.
A corresponding gpkg point table from the same source can be imported
without problem.
I normally use FME to load PostGIS data, else I would probably have come
across this sooner.
*GisKraft*, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220726/4f48dd3b/attachment.htm>
