[Qgis-user] PyQGIS - OGCFeatureService / QgsVectorLayer "OAPIF"
Andrea Giudiceandrea andreaerdna at libero.it
Mon Jun 6 22:53:33 PDT 2022
> Andrew Hughes ahhughes at gmail.com
> Mon Jun 6 02:09:54 PDT 2022
> Yes, thank you! I only tried it about 2 hours ago and the second example
> worked perfectly.
Hi Andrew,
probably the first example doesn't work for you due to the forced text
word-wrap inside the QgsVectorLayer string (a single blank space is
needed between the url='url' and the typename='id' part) in the e-mail
message text.
Even if you have solved the issue, maybe you will find more useful this
little gist:
https://gist.github.com/agiudiceandrea/a8f9b3dc8ff8897c53f7fc9c63faed78
Best regards.
Andrea
