[Qgis-user] how to convert a circular string into a standard linestring?
Alexandre Neto
senhor.neto at gmail.com
Tue Jun 14 12:23:00 PDT 2022
Hello Richard,
Try to use the densify tools from the processing toolbox. Either densify by
count or densify by interval should work.
https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#densify-by-count
The tools can be used as in-place mode, so you can select a specific
feature are run the tools without creating a new layer.
Alexandre Neto
Users support
www.qcooperative.net
A terça, 14/06/2022, 19:24, Richard Greenwood via Qgis-user <
qgis-user at lists.osgeo.org> escreveu:
> I used the Edit menu function "add Circular String" and got just what I
> wanted. But how can I convert it into a regular linestring with a bunch of
> vertices that approximate the curve? Specifically, I need to be able to
> trace the curve with the Split Features tool and trace it when drawing a
> polygon.
> Thanks
> Richard W. Greenwood
> www.greenwoodmap.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220614/d8d0644b/attachment.htm>
