[Qgis-user] how to convert a circular string into a standard linestring?
Richard Greenwood
richard.greenwood at gmail.com
Tue Jun 14 17:25:23 PDT 2022
Thanks Nicolas. I'm using a memory layer. Copying the curve to a
type-constrained layer did convert it to a linestring approximating a curve
but the density tool gives more control.
On Tue, Jun 14, 2022, 4:49 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Also, if your default file format is .shp, then, they will be converted
> automatically.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 14 juin 2022 à 15:28, Richard Greenwood via Qgis-user <
> qgis-user at lists.osgeo.org> a écrit :
> Perfect, just what I needed. Thanks so much.
> On Tue, Jun 14, 2022 at 1:23 PM Alexandre Neto <senhor.neto at gmail.com>
> wrote:
>> Hello Richard,
>> Try to use the densify tools from the processing toolbox. Either densify
>> by count or densify by interval should work.
>> https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#densify-by-count
>> The tools can be used as in-place mode, so you can select a specific
>> feature are run the tools without creating a new layer.
>> Alexandre Neto
>> Users support
>> www.qcooperative.net
>> A terça, 14/06/2022, 19:24, Richard Greenwood via Qgis-user <
>> qgis-user at lists.osgeo.org> escreveu:
>>> I used the Edit menu function "add Circular String" and got just what I
>>> wanted. But how can I convert it into a regular linestring with a bunch of
>>> vertices that approximate the curve? Specifically, I need to be able to
>>> trace the curve with the Split Features tool and trace it when drawing a
>>> polygon.
>>> Thanks
>>> Richard W. Greenwood
>>> www.greenwoodmap.com
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220614/12a7c759/attachment.htm>
