[Qgis-user] polygon fills from different shapefiles
Firstname Lastname byron at conjugategeo.com
Tue Jun 21 07:37:22 PDT 2022
I have gone that far, but I have four sets of maps with similar units.  If
I categorize them independantly, I have to manually change the colours to
make them consistent between layers.   This is very time consuming and I
was wondering if the colour can added to the attribute table so that I can
edit them more easily
On Tue, Jun 21, 2022 at 2:56 AM <geo.guide at web.de> wrote:
> Context menu of your shapefile > properties > choose Tab "Symbology" >
> select "Categorize" in the first line with the attribute for the name of
> the geologic formation as the value in the second line. Click on "Classify"
> and style your polygons as appropriate.
> Regards, Christine
> *Gesendet:* Dienstag, 21. Juni 2022 um 05:19 Uhr
> *Von:* "Firstname Lastname via Qgis-user" <qgis-user at lists.osgeo.org>
> *An:* Qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] polygon fills from different shapefiles
> i have four different geologic maps that i have imported as shapefiles.
> The files have filled polygons that have the name of the geologic formation
> in the attribute tables.  i would like to have a common colour for each
> polygon of identical age/name for all the map sheets.  Each map sheet has a
> similar list of formations, but some of the formations are different for
> each map sheet.
> What is the most efficient way to make the identically named polygons
> displayed with the same colour?  Should i add a column in each attribute
> table and put a formation code in for each one manually or can i add an RGB
> colour for each formation in the attribute table? or, do i need to
> categorize and  classify these in the layer properties table after i have
> added formation code in the attribute table?
> i hope that my question is clear.
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> Cell:4037108414
> _______________________________________________ Qgis-user mailing list
> Qgis-user at lists.osgeo.org List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220621/4dc57027/attachment.htm>
