[Qgis-user] Path along a line
Thayer Young thayeray at yahoo.com
Mon Jun 27 13:19:41 PDT 2022
 Hi Krishna,
Chris was correct about 'Service area (from point)' being the tool you want. I think your problem is that the travel cost is measured in meters not feet.
I will add some detail to his answer. First you should set the 'Path type to calculate' to shortest, and the 'travel cost' to be 304.8. It seems to use meters as the distance cost unit. Also the output seems to be a little wonky if the service areas overlap. You may want to select each point manually and run the tool separately each time.
-Thayer
    On Monday, June 27, 2022 at 03:00:18 PM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
Date: Mon, 27 Jun 2022 12:23:23 -0600
To: chris hermansen <clhermansen at gmail.com>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Path along a line
Message-ID:
    <CADUrCAgx_PWoR88BCsWy=SoMHwPVGdZYVEnnDgNs5XX1MSi0Cg at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Chris,
Thanks for the reply. This does not work. This is only creating a shortest
path connecting all the 5 points. But,I am looking for a path of 1000ft
from each of these points.
Regards.
On Mon, Jun 27, 2022 at 11:37 AM chris hermansen <clhermansen at gmail.com>
wrote:
> Krishna and list
> On Mon, Jun 27, 2022 at 9:58 AM krishna Ayyala via Qgis-user <
> qgis-user at lists.osgeo.org> wrote:
>> Hello,
>> I  have a roads shapefile.  I also have a points shape file with 5 points
>> which are on top of these roads. I wish to extract the roads that are
>> 1000ft along the path from each of these points. I am not looking for roads
>> within 1000ft buffer. I am looking for roads along the path. Can anyone
>> help me with this?
> Have you looked at Processing > Service area (from point)?  Seems to me
> this might do the job for you.
> Chris Hermansen ? clhermansen "at" gmail "dot" com
> C'est ma fa?on de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220627/33a2bc8a/attachment-0001.htm>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220627/747aff3b/attachment.htm>
