[Qgis-user] Simplify geometry - snap to grid
Patrick Dunford enzedrailmaps at gmail.com
Tue Jun 28 16:57:47 PDT 2022
Is this the grid you see in View -> Decorations -> Grid ?
On 29/06/22 07:50, Delaz J via Qgis-user wrote:
> Hi Klaus,
> Just a guess: the only snap to grid thing I know about is
> https://docs.qgis.org/3.22/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#snapping-on-custom-grid.
> Worth a check?
> Regards,
> Harrissou
> Le 28/06/2022 à 15:54, Klaus Mithöfer via Qgis-user a écrit :
>> hello,
>> with the simplify tool in QGIS you can simplify geometries using
>> either  Douglas-Peucker Algorithm, Visvalingam-Algorithm or snap to
>> grid. I understand the algorithms, but how the grid snapping work?
>> Where is is the grid defined? I don't get that point. maybe someone
>> can explain.
>> Thanks an kind regards
>> Klaus
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
