[Qgis-user] Issue with drawing order of layers
Andreas Neumann a.neumann at carto.net
Wed Jun 29 05:28:44 PDT 2022
Hi Roland,
There is a separate panel called "Layer Order" ("Layerreihenfolge" in
German) which can override the order from the layer tree.
Perhaps you/or someone else - accidentally enabled that panel and ticked
the checkbox that it overrides the layer drawing order.
Hope this helps,
Andreas
On 2022-06-29 14:20, Roland Spielhofer via Qgis-user wrote:
> Hi,
> I have a project with several (~50) layers, some of them organised in
> groups, some not.
> Since today, I have an issue with the drawing order - e.g. layers that
> are below others cover layers that are "higher" in the layer list.
> A basemap layer from the bottom of the list e.g. covers now all other
> layers more on top.
> But this is the case for other layers as well.
> I've put three layers into a new project and there the rendering order
> is fine.
> Comparison example here:
> https://imgur.com/a/WOPrLRb
> On the left the new project how it should be - on the right the project
> with the issues.
> The colorful points are the top most layer, but on the right they are
> covered by the grayscale raster image. Ticking off the raster layer
> shows the points again (so I know they are there).
> Any thoughts why this could be? It's QGIS 3.24.0 for some time now, no
> version change. The problem is new by today.
> I didn't find any settings to influence the drawing order.
> Regards,
> Roland
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220629/ce422df0/attachment-0001.htm>
