[Qgis-user] [SPAM] Re: Own processing scripts doesn't load into processing toolbox since QGIS update to 3.22.8.
Wolfgang Meinolf
wmeinolf at bbv-deutschland.de
Wed Jun 29 09:09:30 PDT 2022
Thanks Andrea,
you won't believe it. I ran setup to figure out the versions for you in my mail below. When I clicked the finish button something was unexpectedly installed. I just realized, that I see now all my scripts back in qgis. So it's possible, that Fiona was updated. I use normally the norbit.de mirror, as it's the fastest from here.
However I found now another effect, that produces the following:
"2022-06-29T18:05:19 CRITICAL Konnte Layer ogr:dbname='C:/Users/WMeinolf/WmLocal/LocalTempDir\220620 Check Alg6.1.gpkg' table="Hauspunkte-Test" (geom) nicht erzeugen: OGR-Treiber für '' nicht gefunden (OGR-Fehler: )"
It seems to happen, of the qgs filename contains a . When I rename "220620 Check Alg6.1.qgs" to "220620 Check Alg61.qgs", the error is gone. But this needs some further tects on my side. I had in the past some similar issues with German Special characters (äöüß) in filename or path
Anyway, I am more than happy, that it seems to work again. Thanks for your help!!
Cheers and enjoy the evening
Wolfgang
Von: Andrea Giudiceandrea <andreaerdna at libero.it>
Gesendet: Mittwoch, 29. Juni 2022 17:00
An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>; qgis-user at lists.osgeo.org
Betreff: Re: AW: [SPAM] Re: [Qgis-user] Own processing scripts doesn't load into processing toolbox since QGIS update to 3.22.8.
Il 29/06/2022 12:06, Wolfgang Meinolf ha scritto:
Thanks for your help. I hope it works with the attached zip. Btw, in OSGeo4W Setup we additionally install geopandas, where I am on 0.8.1-2, and rtree (0.9.4-1) and confirm to install all dependencies. I'm on Win10, installed to C:\OSGeo4W
Hi Wolfgang,
I've installed python3-fiona-1.8.21-1, python3-geopandas-0.8.1-2 and python3-rtree-0.9.4-1 and I cannot see any error after putting the two script in the "scripts" folder and launching QGIS 3.26.0: it is then possible to open the algorithms GUI as you can see from this screenshot
https://drive.google.com/file/d/1vbarOQvjya28bU6Qs1CBSe1aEfpCNQ8l/view<https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1vbarOQvjya28bU6Qs1CBSe1aEfpCNQ8l%2Fview&data=05%7C01%7Cwmeinolf%40bbv-deutschland.de%7C39cc958c76dc4e197ba808da59e014a1%7Cba47bf4371d541d1a485dbbab42b8852%7C0%7C0%7C637921116196798951%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=C98p%2Bq4Fu6Ymx89xOMDSwnLp1d99KR%2FM7qrL%2Bl3MeFQ%3D&reserved=0>
Maybe you have a not up to date fiona package?
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220629/b76c4e7b/attachment-0001.htm>
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220629/b76c4e7b/attachment-0001.bin>
