[Qgis-user] Add application_name=QGIS to postgis connection string
Jorge Gustavo Rocha jgr at geomaster.pt
Thu Jun 30 05:16:53 PDT 2022
Hi Toni,
It makes sense to have in all connections to the database. The
application_name is already used by QGIS Server.
To have it in QGIS desktop (from core), a few edits must be made to make
it happen. Maybe there are plug
Can you add this a new feature request?
Regards,
Jorge
On 30/06/22 10:47, Toni Schönbuchner via Qgis-user wrote:
> Hi all,
> my QGIS project is saved in postgres/postgis. The database instance
> exists of 2 databases in
> replication mode (primary, hot standby). Where hot standby is
> readonly. Before them pgpool2
> acts as a load balancer where /WRITE/ only goes to primary and
> /SELECT/ queries go to both.
> My Problem now is, that QGIS uses
> SELECT pg_is_in_recovery();
> to detect if the database is readonly and if so, editing will be locked.
> Now whenever the connection is establish from the load balancer with
> slave (as it sees a SELECT)
> QGIS thinks it cannot write, which is wrong in this situation.
> After advice from a pgpool2 developer I would now force all requests
> coming from QGIS to primary
> only (and allow other clients like dbeaver to use the load balancing
> feature.).
> The way to do this on side of pgpool2 is to catch the application name:
> app_name_redirect_preference_list = 'QGIS:primary'
> I can further already see that QGIS sets a var in postgresql logs.
> Connection matched pg_hba.conf line 94: "host all all 10.201.249.4/32
> scram-sha-256
> 2022-06-30 09:54:40.056 CEST [822446] toni at spatial_db LOG:  statement: SET application_name='QGIS'
> The problem here is, that this var is set _after_ the connection is
> established,
> where I need to set it in the „startup packet“.
> My question is, is there some way to tell QGIS to use a connection
> string like:
> postgresql://10.201.249.2:5432/spatial_db*?application_name=QGIS*
> Or by use of some environment variable?
> Thanks a lot for any help,
> Toni
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220630/66bc2f93/attachment.htm>
