[Qgis-user] Did KML Tools functionality change for everybody else or just me?
C Hamilton adenaculture at gmail.com
Tue Mar 1 10:49:57 PST 2022
Jeff,
I tried points and polygons with graduated symbols and both worked. If you
are using an unsupported style and not just a basic type of style it will
fail although if it is a point layer it can handle more complex styling
because KML Tools exports the icons as png images. Much of the QGIS styling
is not supported by the KML specification and so it becomes impossible to
replicate. It is possible you are trying something that is too complex to
convert to KML styling.
You will need to be more specific on your input data type and how you are
styling it. If you have an example to send me that makes it even easier to
figure out what is going on.
Thanks,
Calvin
On Tue, Mar 1, 2022 at 6:11 PM Jeff Sonnentag <jsonnentag at llenviroinc.com>
wrote:
> I’m positive KML Tools worked perfectly fine before in exporting the
> Symbology style (some Categories of various colors and transparency) the
> same as visible in QGIS.  But now everything comes out one style/color
> rather than the ones they are supposed to be.  I still have the box checked
> for “Export style for single, categorized, and graduated symbols
> [optional]” and also installed the latest version (since I saw there was
> another one).  Restarted QGIS (3.22.24) and it still only puts out a single
> style rather than all the various colors visible in the shapefile in QGIS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220301/3485df5d/attachment.html>
