[Qgis-user] PDFs for testing documentation
Richard Duivenvoorde
rdmailings at duif.net
Thu Mar 3 23:20:12 PST 2022
Hi Julian,
We are more or less planning to create a those sites in coming week.
But in general:
- when 3.22 is LTR we use current /testing version of the docs to create a /3.22 in the docs site and we start translating it
- all newer versions will be redirected to the testing version (only in English)
So in your case you are right:
3.18, and up all point to the testing english version of the doc build
And apparently the pdf build is broken of that, I will look into it:
https://docs.qgis.org/testing/pdf/en/
In the meantime you could take 3.16 version:
https://docs.qgis.org/3.16/pdf/en/
those are also translated:
your other questions:
- every version has it own daily build but only LTR has translated builds
- you could/should take testing to have the latest version, we are working on making that one 3.22 version
Regards,
On 3/4/22 01:32, Julian Pecenco via Qgis-user wrote:
> I recently upgraded to the latest 3.24 release of QGIS, and tried to download the new PDF of the Desktop User Guide as well. (I like to have it on my tablet for offline use.) Only after downloading and overwriting my old version did I realize that the file contains no content. Checking the pdfs for all of the post 3.16 versions, I noticed that they are all only 1.6 M files, so it appears that the PDFs are not being properly generated. The training manual is available, but all of the other files seem to be too small to have any content.
> https://docs.qgis.org/testing/pdf/en/ (replacing testing with 3.22, 3.20 or 3.18 shows the same issue.)
> I'm almost certain I had a Desktop User Guide PDF for some of these older versions, but there's nothing there now. I presume they are bulk processed?
> Does it take a while after a new release for the PDFs to become available, or is this an issue that should be reported somewhere?
> Thanks,
> Julian
