[Qgis-user] Elevation Profiles
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sun Mar 6 11:38:38 PST 2022
This new line is a 3D Line.  This means that every vertex has x,y,z coordinates.  If you want to put that in a field, this is a bit complicated as every vertex has a z dimension.
You could easily use the field calculator to extract the first node or last node z value or could get an average of every z value for the line.  You could also “explode” the line. This would split the line in multiple parts having a maximum of 2 nodes (vertices). Then you could extract the first or last node z value.
Hope this helps.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 6 mars 2022 à 01:07, krishna Ayyala <ayyalakrishna at gmail.com> a écri
> Nicolas, I ran the Drape tool as shown below. It resulted in a new  line feature called "Draped" and added to my map. But this new feature has exactly same attributes as that of "Lines" feature. i.e. it does not have any new field such as Z added to the attribute table.
> Regards.
> <image.png>
>> On Sat, Mar 5, 2022 at 7:07 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> Go in processing and search for “drape”.
>> Nicolas Cadieux
>>>> Le 5 mars 2022 à 14:48, krishna Ayyala via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
>>> Hello,
>>> I have a DEM. I have a vector layer on top of the DEM. This vector layer has 100 lines numbered from 1 to 100. Is there a tool that can generate Elevation and grade profiles along each of these lines? Is there a way to automate this instead of generating each profile individually?
>>> Regards.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220306/fecbfee6/attachment.html>
