[Qgis-user] Automating creation of county distribution maps
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Mar 9 14:09:37 PST 2022
As a newbie, I would start doing is once by hand.  Then, the easiest way is to create a model. You can create a model in the processing plugin.  Make sure the plugin is activated and the panel opened. A model can permit you to link a number of algorithms together.  The other way is to go with python but that is more complicated.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 9 mars 2022 à 12:06, Mike Breiding - Morgantown WV via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Greetings,
> I want to create distribution maps by county occurrence for plant species found in West Virginia.
> What I hope is possible is to load all the county names where a specific species occurs and then have a county map of West Virginia generated with the counties where the species occurs shaded to a particular grey shade and transparency.
> And, while I am wishful thinking it would then be nice to have the output saved to a new layer and then made to a tiff file. All automated a much as possible.
> If I do this manually I have to load the county outline and read a list of county occurrence and then select each one , save to a new layer, choose the shading color and transparency and then take a screen shot of the map area.
> NOTE: I am newbie so if someone comes up with a way to do this I may or may not understand what they are talking about.
> Thanks,
> WV-Mike
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220309/220aee47/attachment.html>
