[Qgis-user] Model Designer - GDAL - Vector Conversion
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Mar 9 14:25:00 PST 2022
To my knowledge, the tab file does not need a FID column to work.  I may be wrong but a geopackage must have a FID column.  I am sure you could create that field afterwards in the model or create a geopackage and then a tab file.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 8 mars 2022 à 18:54, Johanna Botman via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hi Brent,
> I think that is the way that I have to go. I was hoping that it would be a good use of the Modeller
> Johanna Botman
> Assets / GIS Officer – Melton City Council
> From: Brent Wood <Brent.Wood at niwa.co.nz>
> Sent: Wednesday, 9 March 2022 10:50 AM
> To: qgis-user at lists.osgeo.org; Johanna Botman <johannab at melton.vic.gov.au>
> Subject: Re: Model Designer - GDAL - Vector Conversion
> You don't often get email from brent.wood at niwa.co.nz. Learn why this is important
> Have you considered a script or batch file using ogr2ogr to do this for you?
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI:  +64 (4) 3860529
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Johanna Botman via Qgis-user <qgis-user at lists.osgeo.org>
> Sent: Wednesday, March 9, 2022 12:41
> To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Model Designer - GDAL - Vector Conversion
> I am trying to use the Model Designer to automate the creation of Tab files from SQL Database Tables.
> I am using GDAL – Vector Conversion – Convert format
> The resulting Tab file is missing the Primary Key field.
> If use that same algorithm to export to a Geopackage, the PK is there.
> I know that I can right click the SQL Table and select Export. That Tab file contains the PK. I need to export 30 tables so am looking for some automation.
> Why does the algorithm produce a table without the key field?
> Johanna Botman
> The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> Connect with NIWA: niwa.co.nz Facebook LinkedIn Twitter Instagram
> To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220309/461ea1d4/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220309/461ea1d4/attachment.jpg>
