[Qgis-user] Importing spreadsheet: Strange behaviour
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Mar 11 12:52:44 PST 2022
Hi Chris,
mhm.
There are only two columns with ordinary names.
The data holds some special characters, and first I thought this might
influence the process as well. But the version where I deleted those
entries does not behave differently.
Very strange.
Meanwhile, I exported the file to a csv, imported this one successfully
and then saved as gpkg. So at least, the data is in and working.
Thanks,
Bernd
Am 11.03.22 um 21:38 schrieb chris hermansen:
> Bernd and list,
> On Fri, Mar 11, 2022, 12:08 Bernd Vogelgesang via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
> Hi folks,
> for quite some time, I hold frequently changing data in a xlsx-file.
> Working in a spreadsheet application is so much more efficient
> sometimes.
> This spreadsheet easily imports by drag and drop, the import
> dialog pops
> up where to choose which tab to import, and finally the table is there
> with the first row as column heads.
> Now, I'm getting just nuts.
> I'm trying to do the same with other data, and whatever I try, it
> imports the table ignoring the header row, so its Field1, Field2...
> Findings so far:
> I had a long file name. With this, there was no import dialog, but the
> first tab was imported immediately, but without the header row.
> I saved the file with a short file name, and now the import dialog
> asks
> which tab to import. But still, the first data-row is ignored.
> Dragging my other already existing file into that project works just
> perfectly.
> What could be the reason for this behaviour?
> Clutching at straws here...
> Sometimes when making a pivot table in LibreOffice calc I notice that
> column headings (first row) aren't interpreted as such.
> This seems to occur on the following scenarios:
> 1) a column has an en empty cell in row 1 (or missing title)
> 2) a column exists outside the area of interest with no header (this
> probably would not apply in your case, but maybe you have some
> calculations to the right of your data which don't have a column header)
> 3) there are some "strange" characters in one or more header fields (I
> can't recall precisely what constitutes "strange")
> What you might want to do is save a copy of your spreadsheet, then
> delete anything to the left or right of your columns, and check that
> your column names are all "legal variable" names ie begin with a
> letter, only letters and numbers
> I hope this helps; good luck!
> Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220311/a014becc/attachment.html>
