[Qgis-user] Sorting attribute columns in 3.22
Uwe Fischer gisfisch at t-online.de
Mon Mar 14 10:03:48 PDT 2022
Hello,
thanks for the information. Are there more such known traps in 3.22? Could be a reason to go back to 3.18.
Is there information about when it will be fixed? Was hoping a ‚LTR‘ is free of this.
Thank you and regards, Uwe
Von: Totò Fiandaca [mailto:pigrecoinfinito at gmail.com]
Gesendet: Montag, 14. März 2022 16:57
An: Uwe Fischer <gisfisch at t-online.de>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Sorting attribute columns in 3.22
The problem is known,
has been fixed, you have to wait for the next update.
https://github.com/qgis/QGIS/pull/47749
regards
Il giorno lun 14 mar 2022 alle ore 16:52 Uwe Fischer via Qgis-user <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> > ha scritto:
Hello List,
sorting attribute columns does not work like before in 3.22. In the manual, it reads that you can sort by clicking the column header, but that has no effect in my case. What am I doing wrong? There is a small black sorting arrow on the almost left column, but I need to sort by other columns, too.
Best regards and thanks , Uwe
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ing. Salvatore Fiandaca
mobile.:+39 327.493.8955
m: pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>
C.F.: FNDSVT71E29Z103G
P.IVA: 06597870820
membro QGIS Italia - http://qgis.it/
socio GFOSS.it -  <http://gfoss.it/> http://gfoss.it/
blog: <https://pigrecoinfinito.com/>  https://pigrecoinfinito.com/
FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>
TW: <http://goog_95411464>  https://twitter.com/totofiandaca
43°51'0.54"N  10°34'27.62"E - EPSG:4326
“Se la conoscenza deve essere aperta a tutti,
perchè mai limitarne l’accesso?”
R. Stallman
Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220314/5b9d7937/attachment.html>
