[Qgis-user] Trouble loading Grass in QGIS (learning thru the QGIS training modules)
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Mar 18 05:33:36 PDT 2022
> *Dom O*dom225 at gmail.com
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Trouble%20loading%20Grass%20in%20QGIS%20%28learning%20thru%20the%20QGIS%0A%20training%20modules%29&In-Reply-To=%3C200253E8-DD53-43E9-ABD1-17BAB8BB5D5D%40gmail.com%3E>
> /Thu Mar 17 12:48:50 PDT 2022/
> Getting this error when trying to begin GRASS in QGIS:
> "GRASS init error: Problem in GRASS initialization, GRASS provider and plugin will not work : Module built against version 2021-02-10T17:13:06+00:00 but trying to use version 2021-02-10T17:08:53+00:00. You need to rebuild GRASS GIS or untangle multiple installations."
Hi Dom O,
what version of QGIS exactly are you using (look in the Help->About
menu)? What installer have you used to install QGIS on the MacBook
(there are "Official All-in-one" and "Alternative build" installers) and
what version of macOS are you using?
Please see the same "GRASS init error" already reported:
https://github.com/qgis/QGIS-Mac-Packager/issues/120
https://github.com/qgis/QGIS/issues/41782
It seems this issue should only be about the "GRASS 7 plugin" and
shouldn't affect the GRASS processing algorithm functionality. Do the
GRASS processing algorithm works?
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/5022a526/attachment.html>
