[Qgis-user] again: Create Geospatial PDF producing faulty output
Uwe Fischer gisfisch at t-online.de
Mon Mar 21 06:41:36 PDT 2022
Hello dear friends on the list,
I’m sorry but I have to ask again about „Creating Geospatial PDF“ from the
3.22 Print Composer:
does nobody have problems like missing features in the PDF output? The
problem is very important for me, so any idea what the reason is would be
appreciated. Not a single answer until now.
The problem description: some features (in my case line features) are
omitted when QGIS writes the geospatial PDF. Normal PDF output works fine,
as well as TIF image output. So the problem cannot be in the data.
Please help!
Thanks, Uwe
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Uwe
Fischer via Qgis-user
Gesendet: Mittwoch, 16. März 2022 16:26
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Create Geospatial PDF producing faulty output
Hello,
when I chose „Create Geospatial PDF“ from the print composer in 3.22, I get
a PDF with some missing vector lines. I can see no pattern or something like
that in what features are skipped.  „Normal“ PDF output (as well as TIF
image output) is working fine. The setting for „Simplify vectors“ does not
make a difference. Was the same error already in 3.18.
Can anybody please tell me what is going wrong? Creating georeferenced PDFs
with Layer structure is important to my current projects.
And by the way: what is the difference between „Append georeference“ and
„Create Geospatial“ in terms of geolocating?
Thank you and regards, Uwe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220321/d9ef4bbe/attachment.html>
