[Qgis-user] ReportLab integration into QGIS returns error message "no module named reportlab"
    Ludwig Kniprath
    ludwig at kni-online.de
    Mon May  9 00:53:20 PDT 2022
Python inside QGis has no access to plugins installed by pip if called
from normal shell.
But running "pip install reportlab" from the osgeo4w-shell should do it.
"pip show reportlab" after pip-from-shell-installation returns
"Location:
c:\users\ludwi\appdata\local\programs\python\python39\lib\site-packages"
and "import reportlab" in QGis Python Console results
"ModuleNotFoundError: No module named 'reportlab'"
"pip show reportlab" after osgeo4W-shell-installation returns
"Location: c:\users\ludwi\appdata\roaming\python\python39\site-packages"
and no error with "import reportlab" in QGis Python Console
Ludwig
Am 09.05.2022 um 04:52 schrieb julio cesar oliveira via Qgis-user:
> Dears,
> I want to use ReportLab in my own plugin which I have written for QGIS.
> I have installed ReportLab for the python versions 3.10.
> The package is respectively installed into the site-packages folder
> (e.g.
> C:\Users\olive\AppData\Local\Programs\Python\Python310\Lib\site-packages\reportLab).
> If I want to use the tool in my plugin (from reportlab.pdfgen import
> canvas), the plugin returns the error "ImportError: no module named
> reportLab".
> C:\PyQgis\cav> pip install reportlab
> Requirement already satisfied: reportlab in
> c:\users\olive\appdata\local\programs\python\python310\lib\site-packages
> (3.6.9)
> Requirement already satisfied: pillow>=4.0.0 in
> (from reportlab) (9.1.0)
> Do you have any other suggestions or ideas?
> Thanks
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220509/302f4afe/attachment.htm>
