[Qgis-user] add strava heatmap to QGIS
Ujaval Gandhi
ujaval at spatialthoughts.com
Wed May 11 12:12:16 PDT 2022
Hi Hugh,
I made it work successfully in QGIS. The URL needs slight tweaking as
follows
https://heatmap-external-a.strava.com/tiles-auth/all/hot/{z}/{x}/{y}.png?Key-Pair-Id=LONG_STRING
Pro Tip: Use View -> Panels -> Debugging /Development Tools to see the
network request that QGIS is sending out. It helped figure out the correct
url.
On Fri, May 6, 2022 at 9:22 PM Hugh Kelley via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I'm hoping to add the strava global heatmap as a tile layer in QGIS.
> I've done this successfully in the OSM JOSM and ID Editors without a
> problem. this set of instructions/browser plugin is super helpful.
> https://github.com/zekefarwell/josm-strava-heatmap
> without sharing my credentials, the url is just:
> https://heatmap-external-{switch:a,b,c}.
> strava.com/tiles-auth/all/hot/{zoom}/{x}/{y}.png?Key-Pair-Id=ID_STRING&Policy=VERY_LONG_STRING
> <http://strava.com/tiles-auth/all/hot/%7Bzoom%7D/%7Bx%7D/%7By%7D.png?Key-Pair-Id=ID_STRING&Policy=VERY_LONG_STRING>
> It seems that I should be able to plug the same url into the QGIS as an
> xyz layer, but when I do it doesn't work. There's no error or warning, just
> a blank map window. I tried including my strava login in the credentials
> section but this didn't do anything and isn't necessary in the JOSM or ID
> editors.
> Just wondering if anyone can think of any further fixes to try or has
> successfully done this themselves. The heatmap api has changed a bit in the
> past couple years so what worked in the past may not work correctly today.
> Thanks!
> Hugh
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220512/187f1709/attachment.htm>
