[Qgis-user] Error export .shp to .gpx
boxerg at iinet.net.au
Sat May 28 16:15:49 PDT 2022
Hi Mike,
to export points from a shape file to a gpx file, I use the POI plugin. This
plugin allows you to specify which column you want as the point ID.
Cheers Grant
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of
qgis-user-request at lists.osgeo.org
Sent: Sunday, 29 May 2022 3:00 AM
To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 195, Issue 37
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Qgis-user digest..."
Today's Topics:
1. Error export .shp to .gpx (Mike Breiding - Morgantown WV)
2. Re: Error export .shp to .gpx (Fernando M. Roxo da Motta)
3. Re: Error export .shp to .gpx (Mike Breiding - Morgantown WV)
Message: 1
Date: Sat, 28 May 2022 08:14:13 -0400
From: Mike Breiding - Morgantown WV <epicroadtrips at gmail.com>
To: Qgis <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Error export .shp to .gpx
Message-ID: <ba114c2c-c7e9-7585-0f95-8d9f9d6e4e4d at gmail.com>
Content-Type: text/plain; charset=utf-8; format=flowed
Greetings,
I get the following error when I try to export .shp to .gpx.
I do not understand what is meant by "Use GPX_USE_EXTENSIONS creation
option..."
Can any help with this?
Thanks,
WV-Mike
"Export to vector file failed.
Error: Creation of field VERSION failed (OGR error: Field of name 'VERSION'
is not supported in GPX schema. Use GPX_USE_EXTENSIONS creation option to
allow use of the <extensions> element.)"
Mike Breiding
www.EpicRoadTrips.us
Message: 2
Date: Sat, 28 May 2022 09:56:09 -0300
From: "Fernando M. Roxo da Motta" <petro at roxo.org>
Subject: Re: [Qgis-user] Error export .shp to .gpx
Message-ID: <20220528095609.4ade64b8 at cabore.cwbpr.rx>
Content-Type: text/plain; charset=US-ASCII
On Sat, 28 May 2022 08:14:13 -0400, Mike Breiding - Morgantown WV via
Qgis-user <qgis-user at lists.osgeo.org> wrote:
> Greetings,
> option..."
See:
https://gis.stackexchange.com/questions/40731/converting-shp-into-gpx-using-
qgis
> Thanks,
> WV-Mike
> 'VERSION' is not supported in GPX schema. Use GPX_USE_EXTENSIONS
> creation option to allow use of the <extensions> element.)"
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
PU5RXO | PX5Q6048 | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
Message: 3
Date: Sat, 28 May 2022 12:22:25 -0400
To: petro at roxo.org, Qgis <qgis-user at lists.osgeo.org>
Message-ID: <95b8f0de-ab63-c966-ef1e-2edb068868aa at gmail.com>
>> Greetings,
>> option..."
>See:
qgis
Thanks, Fernando.
Did you have a particular solution in mind? There are several listed. I
am a newbie and all of the solutions mentioned are over my head.
I should have mentioned I am using 3.16.16-Hannover on WIN 7
Thanks,
WV-Mike
>> Thanks,
>> WV-Mike
> Roxo
Subject: Digest Footer
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
End of Qgis-user Digest, Vol 195, Issue 37
