[Qgis-user] Watershed - Catchment area upstream of a point
Tony Shepherd (FarmMaps NZ) tony at farmmaps.nz
Tue Nov 8 14:04:02 PST 2022
Hi All
I'm wanting to use a DEM/DTM to automatically map the watershed/catchment
area upstream of a known point.
After a bit of reading, this appears to be a not-so-simple task but
suggestions are to use the "Upslope Area" algorithm.
In my case, the program fails to finish running, and the message window
shows the following error:
             SAGA Version: 7.8.2 (64 bit)
             Error: tool needs graphical user interface [Upslope Area]
             C:\Users\Tony\Documents>exit
Questions:
*	Does anybody know what that error means?
*	Is there another tool/method that is preferable to use?
Cheers
Tony
Tony Shepherd  |  GeoSpatial / Mapping Manager
Ph 027 435 6193  |  E  <mailto:tony at farmmaps.nz> tony at farmmaps.nz  |  W
<http://shepherdphotos.co.nz/> shepherdphotos.co.nz
<https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE
2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221109/30cf8c34/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221109/30cf8c34/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221109/30cf8c34/attachment.png>
