[Qgis-user] Watershed - Catchment area upstream of a point
Shinoto, PD Dr. Maria maria.shinoto at zaw.uni-heidelberg.de
Tue Nov 8 19:15:15 PST 2022
I have used SAGA for hydrological analyses following the instructions in Hans van der Kwast's excellent book on hydroloy in QGIS. It worked well in my Japanese environment, but I forgot about the details.
Still, Hans van der Kwast also showed how to use GRASS for the same purpose. I tried it, it was more hassle than SAGA so I stayed with SAGA. But, maybe it helps you.
There is an instructional video on YouTube:
	https://www.youtube.com/watch?v=aTYHpft1gus
If you did not watch his instructions on using SAGA for that purpose, you may watch his YT videos to check whether you did not forget a step inbetween?
Best,
Maria
> Am 2022-11-09 um 07:04 schrieb Tony Shepherd (FarmMaps NZ) via Qgis-user <qgis-user at lists.osgeo.org>:
> Hi All
> I’m wanting to use a DEM/DTM to automatically map the watershed/catchment area upstream of a known point.
> After a bit of reading, this appears to be a not-so-simple task but suggestions are to use the “Upslope Area” algorithm.
> In my case, the program fails to finish running, and the message window shows the following error:
>              SAGA Version: 7.8.2 (64 bit)
>              Error: tool needs graphical user interface [Upslope Area]
>              C:\Users\Tony\Documents>exit
> Questions:
> 	• Does anybody know what that error means?
> 	• Is there another tool/method that is preferable to use?
> Cheers
> Tony
> Tony Shepherd  |  GeoSpatial / Mapping Manager
> Ph 027 435 6193  |  E tony at farmmaps.nz  |  W shepherdphotos.co.nz
> <image001.jpg>
> <image002.png>
> Qgis-user mailing list
