[Qgis-user] qgis project to online
Julien Cabieces julien.cabieces at oslandia.com
Wed Nov 9 05:37:39 PST 2022
You need to install[0] and configure[1] a QGIS server on your server so you
can stream the project and its data to your web client using for
instance WMS.
Your data need to be either on a database (PostGreSQL/PostGIS for
instance) or inside files side-by-side with your project file (but it's
less efficient, better to have them in a database).
Your web client can then use the WMS to display the map using a library
like OpenLayers, LeafLet or an tire web application like QWC2[2], Lizmap[3]
(there is many more)
Regards,
Julien
[0] https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#installation-on-windows
[1] https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#serve-a-project
[2] https://qwc-services.github.io/
[3] https://www.lizmap.com/en/
> Hello everyone!
> Can somebody, please, provide me with hints and directions on where
> should i start with understanding on how to make that the projects we
> work on to be available online, on a web interface?
> What i understand is that we need a server where the project should be
> uploaded (which we have) in order to be visualized.
> What i am missing is how exactly i do that?
> I started looking postgis, postgresql, geoserver. But at this point i am
> lost as i am not sure what do i do next.
> I know that we need to configure somehow our server, but how exactly i
> am not sure.
> I need to mention one more desirable thing: what we need is that as we
> edit a project, these edits need to appear in the online map too.
> I'm operating on windows 11.
> Thank you in advance!
