[Qgis-user] SRTM problem
Shinoto, PD Dr. Maria maria.shinoto at zaw.uni-heidelberg.de
Tue Nov 29 03:32:03 PST 2022
I had the same problem, and Nicolas Cadieux helped me with this hint two years ago:
Quote:
It's just the Z factor needed when you make a hillshade when the x an y
are in degrees and the z is in feet or meters (like SRTM). You can see  it if you choose Hillshade under symbology / render type (for a raster  layer).  It's basically the length of a degree in meters for latitude.
https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-z-factor-parameter-correctly/
This helped perfectly.
Best,
Maria
> Am 2022-11-29 um 17:17 schrieb Lazanu Ciprian-Cătălin via Qgis-user <qgis-user at lists.osgeo.org>:
> Hello,
> I have a project and I want to create a map using SRTM as a background.
> I upload it ... and looks like that ... <QGIS_01.jpg>
> but my project area is smaller, so I need to zoom it ... and when I do that, my SRTM looks like that ...
> <QGIS_02.jpg>
> What can I do so the raster doesn't look so pixelated?
> Thank you.
> Qgis-user mailing list
