[Qgis-user] Problem Noticed with QGIS
Richard McDonnell richard.mcdonnell at opw.ie
Tue Nov 29 09:05:11 PST 2022
Andrea,
Thank you for the clarification and the work around!
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrea Giudiceandrea via Qgis-user
Sent: 29 November 2022 16:14
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Problem Noticed with QGIS
Richard McDonnell richard.mcdonnell at opw.ie<mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Problem%20Noticed%20with%20QGIS&In-Reply-To=%3C9708d6dac99943929281a173e54a9e6f%40opw.ie%3E>
Tue Nov 29 07:17:48 PST 2022
1.       If I use the option [Create temporary Layer] it produces a Singlepart Geometry as Expected, If I save the output to a File, the resultant geometry is stated as Polygon (MultiPolygon) Its the same for Linestrings also.
Hi Richard,
as explained (also by me) in the linked issue report [1], the line (PolyLine) and polygon (Polygon) ESRI Shapefile layer types are actually multi-part layer types which can store both multi-part geometries with only one part and multi-part geometries with more than one part.
Only the point layer type has two different ESRI Shapefile layer types: the ESRI Shapefile Point type (which is a single-part type and can store only single-part geometries) and the ESRI Shapefile MultiPoint type (which is a multi-part type and can store multi-part geometries both with only one part and with more than one part).
Please see the ESRI Shapefile Technical Description [2].
If you want to check that a line (PolyLine) and polygon (Polygon) ESRI Shapefile layer imported in QGIS contains features with only 1 part, you need to check the number of part for each feature, for example using the num_geometries function [3] in the field calculator.
Best regards.
[1] https://github.com/qgis/QGIS/issues/50720
[2] https://www.esri.com/Library/Whitepapers/Pdfs/Shapefile.pdf/
[3] https://docs.qgis.org/3.22/en/docs/user_manual/expressions/functions_list.html#num-geometries
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221129/72d9e839/attachment.htm>
