[Qgis-user] ogr2ogr slow
Andrea Giudiceandrea andreaerdna at libero.it
Tue Oct 18 10:13:36 PDT 2022
> *Dennis Burgess*
> /Mon Oct 17 14:46:19 PDT 2022/
> but when OGR2OGR gets that data, then does whatever it needs to on GPKG file, it only uses about 5% of the CPU
Hi Dennis,
that happens probably because the CPU is a multi-cores / multi-threads
CPU with tens of cores / threads and the GDAL/OGR library or tool only
uses one core / thread to execute such task.
I would suggest you to have a look at [1] and [2] for some performance
improvement hints and to ask to the gdal-dev mailing list subscribers if
you won't receive enough replies through this mailing list.
Best regards.
[1] https://gdal.org/drivers/vector/gpkg.html#performance-hints
[2] https://gdal.org/programs/ogr2ogr.html#performance-hints
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221018/5f83f7ca/attachment.htm>
