[Qgis-user] ogr2ogr doesn't connect to MS SQL Server
Reetz, Michael (NLPV) Michael.Reetz at nlpvw.niedersachsen.de
Thu Oct 20 04:59:15 PDT 2022
Hi Andrea and Ian,
yes, I’ve read the documentation and a lot of other tips. I’ve signed in to the gdal-dev mailing list and will post my problem there as soon as the registration is done. I will post the result here if there is a solution.
Thanks and best regards
Michael
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Andrea Giudiceandrea via Qgis-user
Gesendet: Donnerstag, 20. Oktober 2022 11:14
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] ogr2ogr doesn't connect to MS SQL Server
ACHTUNG!! Diese E-Mail erreicht Sie von einem Absender außerhalb der niedersächsischen Landesverwaltungs-Infrastruktur mit TLS-Verschlüsselung. Bitte klicken Sie auf keine Links oder öffnen Sie keine E-Mail-Anhänge, falls Sie den Absender nicht kennen und nicht wissen, ob der Inhalt sicher ist.
Thu Oct 20 01:39:42 PDT 2022
So, it looks as if ogr2ogr is not really helpful for me and I have to look for another tool.
Hi Michael,
AFIAK QGIS has its own MSSQL provider since 2012, while ogr2ogr relies on the GDAL/OGR library to connect to an MSSQL server: have you already read the documentation at [1]?
I suggest you to also ask the gdal-dev mailing list [2] for help.
Best regards.
[1] https://gdal.org/drivers/vector/mssqlspatial.html
[2] https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221020/716c27bd/attachment.htm>
